lekw310388
Jan 25, 2017Star
Speed from 500mbps down to 25mbps
So i just received the Orbi yesterday and have it setup. The good news is, I have full signel all over my house. The bad news is, if I tested the speed via ethernet cable between the rounter and ...
st_shaw
Jan 30, 2017Master
lekw310388 wrote:
Thanks for clearing that for me.
Anyway, is there any solution for you give me? Maybe ditch the orbi system and replace it with something different?
You can't beat physics. If you need to cover multiple floors in a concrete building, then I think you either need to live with the 25 Mbps speed (which isn't bad) or use some kind of wired solution. Wired could include Ethernet cable, telephone lines and the VDSL solution I posted above, or TV-style coax wires and a MOCA converter (which runs Ethernet over coax.)
lekw310388
Feb 17, 2017Star
Yes, I just did a full reset by pressing those little hole at the back, and have it set up again. Well, no luck.
This is the speed i'm getting when I connect my laptop via cable to the router:
And this is the speed I got (wifi) when I'm in my room, on the 3/F, while the satellite is placed on the 2/F:
So what's the deal here?
