lekw310388
Jan 25, 2017Star
Speed from 500mbps down to 25mbps
So i just received the Orbi yesterday and have it setup. The good news is, I have full signel all over my house. The bad news is, if I tested the speed via ethernet cable between the rounter and ...
csk
Feb 17, 2017Aspirant
Am suspecting the problem might be with your modem.
Did you set your modem in bridge mode?
I had the same problem getting 10 Mbps instead of 300 Mbps that I subscribe.
I factory reset my modem, set it in bridge mode, my speed has been steady between 290 up to 320 Mbps .
You might also need a third orbi Satelite for the 3rd floor
