Johan_E
Nov 29, 2020Follower
Speed in a 1+3 setup RBR50
Hi
I have significant problems to get good speed from my Sattelites. The Router is an RBR50 and the sattelites is RBS50 (i think). When I test I get an access of approx 30Mbit on the wireless laptop connected to sattelite while the Router connection is 250Mbit. What can possibly be wrong and what to do about it?
Johan
1 Reply
Are you disabling the wifi devices wifi radio for 5 seconds, then go near the RBS, then re-enable the wifi radio on the device then speed test?What devices are you speed testing with?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
