BigDingus
Apr 11, 2024Tutor
Speed Loss
Hi folks. Can anyone tell me what the maximum speed the RBR50 can handle? My ISP's router delivers 130gbs but my Orbi RBR50 is only passing 90gbs. I'm wondering if 90gbs is the max it can handle.
- Apr 19, 2024
Thanks for taking the time to help folks.
After trying everything without any resolution, I removed everything and reset everything to factory.
After I reinstalled everything using new (different) cables, my speed jumped to what they should have been.
What fixed it? I don't know, but thanks again guys.
Apr 11, 2024Guru - Experienced User
Wired ethernet can do near 900Mpbs.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure the connection rate between the ISP modem/ router and RBR is 1000Mpbs. Check the RBRs web page under Advanced tab/Show Stats. WAN port should show 1000Mpbs. Same with a ethernet connected PC connected to the back of the RBR.
Wireless speeds can differ and will not see near 900Mpbs over wireless. Max speeds seen over wireless could be 300-500Mbps depending on wifi device design and support.
Armor, Smart Parental Controls or Circle, Traffic Meter.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
