BigDingus
Apr 11, 2024Tutor
Speed Loss
Hi folks. Can anyone tell me what the maximum speed the RBR50 can handle? My ISP's router delivers 130gbs but my Orbi RBR50 is only passing 90gbs. I'm wondering if 90gbs is the max it can handle.
- Apr 19, 2024
Thanks for taking the time to help folks.
After trying everything without any resolution, I removed everything and reset everything to factory.
After I reinstalled everything using new (different) cables, my speed jumped to what they should have been.
What fixed it? I don't know, but thanks again guys.
BigDingus
Apr 19, 2024Tutor
Apr 19, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
