butterwm1
Sep 18, 2017Aspirant
Speed Question
We have AT&T fiber internet which is supposed to run at 1,000 MB/s upload and download. I have the wireless turned off on their router and then have the Orbi router connected to that router via ethe...
TheEther
Sep 18, 2017Guru
By convention, MB/s means megabytes per second. Internet speeds are usually expressed in megabits per second, or Mb/s or Mbps. I'm gonna assume your numbers are in Mb/s.
Anyway, 95 Mb/s is often a sign that one of the connections is running at 100 Mb/s. This could be due to a bad Ethernet cable. If you have a spare, try it.
