Justwords
May 04, 2019Tutor
Speed test limited to 500 Mbps?
I have a DOCSIS3.1-Connection and have one RBR50 and two satellites connected to a FritzBox 6591. While doing a manual speed test e.g. via speedtest.computerbild.de i often get speeds of above 950 Mb...
Daniel84
Jun 21, 2019Tutor
Same issue here (1Gbps download/upload link) download no more than 510 Mbps but upload reaches until 800 Mbps. For the other ones answering, understand the test even if done my the mobile app, is testing the orbi router connected by ethernet to the modem!.
I tested an apple tv using the speed test app connected to the orbi via ethernet and got download speeds above 700 Mbps so it seems its something about the speedtest servers!?
Jun 21, 2019Guru - Experienced User
Probably...
