NielT
Apr 19, 2019Follower
Speed testing Orbi90
When I run the speed test from the Orbi app it shows about the same high speed as my cable provider advertises. But if I run a speed test from the laptop when it's just connected to the Orbi network ...
Apr 22, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of this laptop?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try a different wireless device to compare...
NielT wrote:
When I run the speed test from the Orbi app it shows about the same high speed as my cable provider advertises. But if I run a speed test from the laptop when it's just connected to the Orbi network by wifi the results are very slow. Why?
