Wakey
Nov 02, 2019Star
Speeds have plummeted after latest update.
New to Orbi and have been delighted with its speed. I have 500 internet and all over the house was getting very fast speeds and always without exception full upload speed of 35. As soon as I’ve u...
Nov 02, 2019Guru - Experienced User
Try a factory reset and setup from scratch if you see this problem again after updarting FW. Some have not done this and not given a full reset and setup a try. it does work and helps in these cases where users upgrade and see bad behavoir. I know a reset shouldn't be main stream however for some cases, it needs to be give a chance. I saw no speed loss after upgrade to v38 and had great operation. However I alwaya manually update and factory reset and start out fresh. Just works. Others as well:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Good Luck.
Wakey wrote:New to Orbi and have been delighted with its speed. I have 500 internet and all over the house was getting very fast speeds and always without exception full upload speed of 35.
As soon as I’ve updated the firmware it has plummeted in speed. You can see the exact moment my firmware was updated on the Speedtest history, and even upload speed seems halved.
How can Netgear release a firmware update that trashes the product?
Any ideas. I bought this system as consumer friendly with no rigmarole, will resetting it and all the hassle that requires even work? Why should you have to do that?
I see others are reporting similar issues and resetting did not work for them and they have rolled back the firmware. I have no idea how to do this and only use the app- my web browsers (Chrome and Safari) cannot for some reason connect to it on my Mac (could not when I bought it a few weeks ago).
Very sad as I had a great system, now it is trash.
Thanks everyone.
- Orbi-RocNov 02, 2019Luminary
Same here FURRYe38 . A factory reset after each firmware update has kept me safe from all those issues I read about. Just curious Wakey -- did you check your log? Just wandering if perhaps something else is getting in the way and causing your system down to crawl.
- WakeyNov 02, 2019Star
I didn’t check any log, but it slowed when the new firmware was installed, and went back to how it was when I rolled it back, so it seems to be the firmware. It also seems to be the firmware on the satellites from the fact it went back to what it was when the satellites were rolled back before the router itself. Router has always showed 500+ speed when doing a speedtest on it even after the dubious new firmware was installed, so it was either the backhaul or the wireless performance that was degrading under new firmware.
I’ve seen a lot of reports across the internet of the same thing, so for some reason this firmware is affecting a lot of people. Have you got a very fast internet connection of plus 200 because the reports seem to be coming from those people?
- Orbi-RocNov 04, 2019Luminary
Hi again Wakey . Yes, I understand. But you attribute the performance loss directly to Netgear's latest firmware; and although this be indeed be the case, one would think that ALL users would be experiencing the same thing; which I do not believe to be the case. The reason I was asking if you checked your Admin log is to see if, by any chance, you may have been bombarded with DoS attacks which can bring any network down to crawling speed and even bring the network down competely. Not every time, but I've had many instances of performance degradation; and upon checking the router's Admin log, I would find hundreds of DOS records. But I am no expert in the field, far from it. Just thought I'd pass it on any way.
