alokeprasad
Feb 10, 2021Mentor
Speedtest in the Orbi web interface
Any idea what servers are used by the Orbi web interface's Advanced -Setup - Speed Test? I always get way higher numbers using this compared to all other speed tests (including tests at Ookla's web ...
alokeprasad
Feb 10, 2021Mentor
For example:
Orbi 479/12 Mbps
Speedtest.net 301/13.2
Fast.com 150/13
Google 227/14.8
These use different (single vs multi threaded downloads etc.) methods, but one would expect Orbi and Speedtest.net to be similar in their methods.
Feb 10, 2021Guru - Experienced User
How are you comparing speed tests?
Are you using a wired in computer or wireless?
When you use the orbi app's speedtest, it hosts the test directly off the router.
Versus if you're using the speedtest app or browser based method, its hosted on the computer/phone you're testing with. If that device is wireless, then the wireless tends to be the speed bottleneck.
- alokeprasadFeb 10, 2021Mentor
Using PC connected via ethernet directly to the RBR.
Link speeds is 1 Gbps between RBR and the PC.
BTW, I'm paying my ISP for a 400/15 Mbps service. So, the Orbi results are a bit better but not impossible.
- plemansFeb 10, 2021Guru - Experienced User
What modem are you connected to?
did you try different server's using speedtest?
Also, are you using armor, traffic monitoring, access controls, parental controls, qos, etc? Try disabling those and rebooting.
- FURRYe38Feb 10, 2021Guru - Experienced User
Speedtest.net 301/13.2> Are you usiing the web browser based site or the installable speed test app?
I find that the speed test app is more accurate.
Also depending on sites you select for your location, these can be a factor as well. I pick one site that gives the best results. Others maybe either busier that others or at a distance.
I find that other test sites are not as accurate as Ookla. Even MS Network speed test doesn't see my full 900Mpbs.
