alokeprasad
Feb 10, 2021Mentor
Speedtest in the Orbi web interface
Any idea what servers are used by the Orbi web interface's Advanced -Setup - Speed Test? I always get way higher numbers using this compared to all other speed tests (including tests at Ookla's web ...
Feb 10, 2021Guru - Experienced User
Speedtest.net 301/13.2> Are you usiing the web browser based site or the installable speed test app?
I find that the speed test app is more accurate.
Also depending on sites you select for your location, these can be a factor as well. I pick one site that gives the best results. Others maybe either busier that others or at a distance.
I find that other test sites are not as accurate as Ookla. Even MS Network speed test doesn't see my full 900Mpbs.
alokeprasad
Feb 10, 2021Mentor
Some combined answers:
Modem used: Arris SB6190
Speedtest servers in my tests: I usually let it select the server. It selects one typically within 20 miles of me. It also selects a host hosted by my ISP (which should be the fastest with fewer hops).
Not using any Armor, access control, parental control or filtering on the Orbi.
Windows Speedtest app results: 236/16 Mbps
Orbi 479/12 Mbps
Fast.com 150/13
Google 227/14.8
Official speed for my service: 400/15
I expect some variation between sites and time of day.. I was curious why Orbi's tests (which uses Ookla's engine) gives higher values than the Ookla app or web site. How/which server does the Orbi choose?
Its not a big deal or a problem. Do you all see better numbers from the Orbi's built-in tests?
