dirceuguerra
Jun 02, 2019Aspirant
Speedtest via router x speedtest via app
Hello. I’m using an Orbi RBR-50 + RBS-50 + 2 RBS-40. The satellites are all connected via gigabit ethernet on the RBR-50. Orbi is working as router mode and all of them updated to the latest firmwa...
Jun 02, 2019Guru - Experienced User
What FW is currently loaded?
Orbi is working as router mode and all of them updated to the latest firmwares.
I used to work in AP mode. And everytime I used to do speedtest in orbi’s app, i got the real speed performance contracted.
Since I’ve changed Orbi’s to work in router mode, most of this in app speedtest shows a slow speed in up and downloads. Almost 10x slower.
The strangest thing is, if I do the test in my wired macbook, it shows the real speed. In speedtest app over IOS, the same. I’m only getting strange results over Orbi’s in app speedtest.
- dirceuguerraJun 02, 2019AspirantIt’a a Sagemcom F@st 5655 v2. I live in Brazil and my internet provider is Tim Live fiber with 300mb download and 180 upload.
All Orbi’s uses the latest firmware. RBR 50 and RBS 50 uses 2.3.1.60. The two RBS 40 satellites uses 2.3.1.58.
A strange thing I noticed today bur haven’t gone too deep yet is that a speedtest using Ookla app when my iPhone is connected in Orbi’s router shows the same low up/down speed that Orbi’s in app speedtest.
When I’m connected over any of the satellites, i have full speed (300dw/180up) on ookla’s app.
It seems the problem is restricted to the RBR-50 unit.- ekhalilJun 02, 2019MasterDo you happen to have WAN Port mirror to LAN port1 enabled in the Router’s debug page?
- dirceuguerraJun 02, 2019AspirantNo, should I do that?
All options on debug page are empty
- FURRYe38Jun 03, 2019Guru - Experienced User
You seem to have a modem with a built in router as well.
FYI,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
It seems the problem is restricted to the RBR-50 unit.- dirceuguerraJun 03, 2019Aspirant
It's really very strange...
I've done a factory reset and I keep getting the same behaviour from the Orbi base station. Full or almost full download speed and a slow upload speed.
When I get close to the the satellites, I get full download and upload speed.My internet provider made a very simple step to configure the modem as bridge. After I log into the modem (192.168.1.1), they only give two options: turn Wi-fi on or off and change the modem to bridge mode. They don't have an advanced mode to check other options.
So, I just checked the bridge mode, the interface tells me they gonna shut off the buit-in wireless and gives me the credentials to log-in into Orbi.
I could post some prints, but they are in portuguese, I think it's more easy to describe it here.
