dirceuguerra
Jun 02, 2019Aspirant
Speedtest via router x speedtest via app
Hello. I’m using an Orbi RBR-50 + RBS-50 + 2 RBS-40. The satellites are all connected via gigabit ethernet on the RBR-50. Orbi is working as router mode and all of them updated to the latest firmwa...
dirceuguerra
It’a a Sagemcom F@st 5655 v2. I live in Brazil and my internet provider is Tim Live fiber with 300mb download and 180 upload.
All Orbi’s uses the latest firmware. RBR 50 and RBS 50 uses 2.3.1.60. The two RBS 40 satellites uses 2.3.1.58.
A strange thing I noticed today bur haven’t gone too deep yet is that a speedtest using Ookla app when my iPhone is connected in Orbi’s router shows the same low up/down speed that Orbi’s in app speedtest.
When I’m connected over any of the satellites, i have full speed (300dw/180up) on ookla’s app.
It seems the problem is restricted to the RBR-50 unit.
Jun 03, 2019Guru - Experienced User
You seem to have a modem with a built in router as well.
FYI,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- dirceuguerraJun 03, 2019Aspirant
It's really very strange...
I've done a factory reset and I keep getting the same behaviour from the Orbi base station. Full or almost full download speed and a slow upload speed.
When I get close to the the satellites, I get full download and upload speed.My internet provider made a very simple step to configure the modem as bridge. After I log into the modem (192.168.1.1), they only give two options: turn Wi-fi on or off and change the modem to bridge mode. They don't have an advanced mode to check other options.
So, I just checked the bridge mode, the interface tells me they gonna shut off the buit-in wireless and gives me the credentials to log-in into Orbi.
I could post some prints, but they are in portuguese, I think it's more easy to describe it here.
- dirceuguerraJun 23, 2019AspirantSo, after some weeks of tests, still have the instability with the speed and noticed a new one. From time to time, the router lose the connection.
In the beginning i tought it was an issue with the internet provider, but no. All wireless connection lose internet, but wired was still up.
Then, decided to change Orbi from AP to bridge mode and it seems to be OK now, with full download and upload speed.
It seems like an issue with AP mode or with provider’s modem, or maybe both.
Will try to figure this out with the provider because i really wanted AP mode for Armor and upnp.- FURRYe38Jun 23, 2019Guru - Experienced User
Try configuring the modem for router mode and try option #2 of my suggestion about modem combo units. Configure the Orbi for router mode and use the DMZ on the modem for the Orbi. I would not recommend using Armor, others have reported having problems with it.
