JImDonahue
Dec 17, 2021Aspirant
Speedtest weirdness
My Orbi gives Speedtest reading of around 50Mb down, but when I run Speedtest on my iPad I get download readings more like 600Mb. The upload readings from the two tests are very close.
The built in speedtest isn't that accurate because of how it chooses test servers. If it chooses the closest server but that server is running slow, you get inaccurate readings.
the one you use off the speedtest app works better and is more accurate.
- JImDonahueAspirant
This seems to have changed recently. I've been using Speedtest on Orbi for several months and never saw this behavior. And why should the Orbi version choose servers any differently than the Speedtest IOS app?
Because the orbi speedtest thats built in uses a different algorithm to determine which to test off than what the actual speedtest app uses.
It might have been testing off a server and a new one was added that doesn't have the same capability.
Or the one it used to test off is having issues.
but if the actual speedtest site is giving you the results you expect, thats what I'd go off.
