robdonald
Apr 03, 2024Tutor
Splitting 2.4G and 5.0G Signals
Hello, Given the number of IoT devices that exist which only use a 2.4G connection, when is Netgear going to make it easy to connect a device without having to start modifying the router's firmwa...
- Apr 04, 2024
Newer Orbi AX and beyond systems do have support for legacy devices. I also have a few cameras that are 2012 era and still connecting to Orbi AX, AXE and BE systems. Even with Mixed Mode WPA2 and WPA3 set. However there are other devices that won't connect if WPA3 is in the mix. Why NG implemented the separate IoT network on Orbi AX and beyond systems. There is some compatibility there.
Apr 03, 2024Guru - Experienced User
Orbi AC series never supported separation of SSID across the frequencies. Was only last year that NG introduced a separate configurable IoT SSID network on the Orbi AX and AXE series.
https://kb.netgear.com/000064269/How-do-I-change-the-Internet-of-things-IoT-network-name-SSID-and-password-on-my-Orbi-WiFi-6E-System
Something that NG probably wont be putting on the Orbi AC series since it's EoL now.
If your interested in this feature then you'll need to upgrade to a Orbi AX or AXE system or find something that suits your needs.
Good Luck.
