Darian2498
Apr 28, 2019Aspirant
Sporadic Ping Spikes over 5Ghz wifi.
I recently purchased this Orbi Modem/Router combo system so I could get more coverage in my house. It connects and reaches all areas fine now, except one issue. I like to play videogames, particularl...
Darian2498
Apr 29, 2019Aspirant
The 5Ghz wireless channel, as the post says.
SW_
Apr 29, 2019Prodigy
Do you see a similar spike when you ping the Satellite vs Router?
For examples:
1. telnet to Satellite and ping the Router
2. then ping google.com from Satellite
3. telnet to Router and ping the Satellite
4. then ping google.com from Router
This will give an idea if there's an issue with Orbi wireless backhaul.
Do you have similar problem when playing the game via wired connection?
- Darian2498Apr 30, 2019Aspirant
I factory reset and turned off the Daisy-chain mode (whatever it was called) at has seemed to resolve the problem. Opon doing so, the backhaul status also went from poor to good, so idk what was going on there. Anyway, thanks for the help.
- Darian2498May 02, 2019Aspirant
Update: Ping is still spiking to around 1200+ and then returning back to normal. I thought I had fixed it, but apparently. Still not sure what the issue is.
- SW_May 02, 2019Prodigy
Darian2498 , can you head over here to check your backhaul signal?
I'm connected to the main unit, not the satellite. Is it still necessary?
