Darian2498
Apr 28, 2019Aspirant
Sporadic Ping Spikes over 5Ghz wifi.
I recently purchased this Orbi Modem/Router combo system so I could get more coverage in my house. It connects and reaches all areas fine now, except one issue. I like to play videogames, particularl...
May 13, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Darian2498 wrote:
I recently purchased this Orbi Modem/Router combo system so I could get more coverage in my house. It connects and reaches all areas fine now, except one issue. I like to play videogames, particularly Rainbow Six: Siege. Before, with the Modem and Router provided by my ISP (Spectrum), my ping and pakcet loss was fine. Now, with this Orbi, I have been experiencing major ping spikes. It will go from the normal of ~36 to 1000+. The game we "freeze" and then fix itself around 1.5 seconds after. I've tried factory reset, disabling and enabled portforwarding, updating firmware, pretty much everything, but the problem stil persists. Any ideas or soluions? Thanks.
