Rabert101
Oct 05, 2021Aspirant
SRR60 stuck on solid white after firmware update
After successfully upgrading my SRR60 & conected satalites last night to firmware 2.7.0.122, this morning the router rebooted itself & was stuck on solid white ring for hours. After troubleshooitng &...
Oct 05, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi Pro (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Thank you.
Rabert101 wrote:
After successfully upgrading my SRR60 & conected satalites last night to firmware 2.7.0.122, this morning the router rebooted itself & was stuck on solid white ring for hours. After troubleshooitng & several reboots I bit the bullet & reset to factor default settings. Much to my disappointment, still solid white ring... can't connect, can't login - nothing, just a brick.
Any suggestions?
