rawb1's avatar
rawb1
SSH into Orbi - RBR850
Hi all:
BTW:  Model field in the submission form won't allow me to enter RBR850
Subject at hand:
I'd like to shell into my Orbi to set up DHCP6-PD by editing my dhcp6c.conf file as per this:
https://community.netgear.com/t5/Orbi/IPv6-DHCPv6-Prefix-Delegation/m-p/1733231/highlight/true#M58666
This seems to be the way to enable IPV6 because my ISP requires a IA-PD and NO IA-NA.
However, I cannot find the place to enable SSH (or god forbid Telnet) in the GUI interface.
I searched here and I've seen mention of secret HTML menu's etc. but no success so far.
Thanks in advance
    It is really annoying that Netgear does not assign someone to keep the list of products up to date.
    Alas, there is no known method to enable SSH or telnet on the AX series of routers.  The most recent firmware release for the original Orbi series removed telnet from the 'debug' menu, but there is a Python script that can be used to enable it. (I do.)  So modifying configuration files is not going to happen.
    Can you identify which ISP  forbids an ia-na parameter?  I cannot imagine the ipv6 configuration file being different from one Netgear router to another, so this would seem to make all Netgear routers incompatible with this ISP.  And, you've probably had this 850 more than 90 days and thus cannot contact Netgear.
    Wow, this question is 'deep in the weeds'.  My head practically swims trying to understand, for example:
    https://www.juniper.net/documentation/us/en/software/junos/subscriber-mgmt-sessions/topics/topic-map/dhcpv6-iana-prefix-delegation-addressing.html
    I would be tempted to use the debug option to 'capture WAN/LAN traffic' and Wireshark to see exactly what the Orbi is sending during the startup discussion.
  • CrimpOn's avatar
    CrimpOn
    • rawb1's avatar
      rawb1
      Thanks heaps for the quick reply:
      The ISP in question says this:
      dhcp6-pd is required:
      - it should only send IA-PD
      - if it sends BOTH IA-NA AND IA-PD in solicit message:
      > - must conform to RFC7550
      > - this is superseded by RFC8415
      How they get around this is that the router that they send out supports this, but I just connect directly to the ONT and don't use their router.
      I guess I'm hooped, and yes, it is more than 90days!
      Thanks again
      Notes:
      > > - IA_NA = Non temporary
      > >- PD = Prefix delegation
      > > - IA_TA = Temporary
      > > - IA = Identity association
      • CrimpOn's avatar
        CrimpOn
        Well, having two routers (Double NAT) is only an issue if there are specific features which are important to you and incompatible with Double NAT. (OpenVPN, forwarding ports is much more cumbersome, some internet gaming)
  • FURRYe38's avatar
    For you future needs,
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you
