giuseppeselli
Jul 25, 2022Follower
ssh port 22 forwarding on RBK53
Hi all, I am having some issues in forwarding the ssh port (22) through the router...it seems very straightforward from the user manual, but the connection in not sent through. Any suggestions on...
Mikey94025
Jul 25, 2022Hero
Check the Community FAQ for how to use https://canyouseeme.org/ and first verify that your port is visible outside: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/1984296. Make sure you're not running Double NAT or else one port forward is insufficient.
What OS is the host running that you're trying to SSH to? If Windows check the firewall per the FAQ.
