MelvinV's avatar
MelvinV
SSID Intermittently Disappearing
Hi, I just bought an Orbi RBR20 with 2 Satelites (only using 1). I have 1Gig with Verizon Fios>pfSense router >Unifi switch>Orbi. My Orbi is in AP mode. This problem was occuring on firmware 2.3.5.30...
  • MelvinV's avatar
    MelvinV
    Sep 15, 2020
    Connecting directly to the modem did not resolve the issue. After further investigation I realized that the router device was actually losing its Internet connection. I went out and purchased a new device in so far so good with all the default settings. Thank you for your help.
