twocybers
Dec 21, 2016Star
SSID Naming
Is it possible to create different SSIDs for the 2.4 & 5 GHz networks? Say twocybers and twocybers 5GHz
qskillzwfu25
Dec 21, 2016Tutor
Right now there is not an option to have two separate SSID names. Can only designate one and the software manages which network your device connects to (2.4 vs 5GHz). As an option you can enable the guest network and name that something different but again the software will determine which band the device connects to (2.4 vs 5GHz).
twocybers
Dec 21, 2016Star
Thanks - that is what I thought the situation was.
