rugbydman
Apr 05, 2018Aspirant
SSID Naming
Hi. I just got my orbi rbk50. When setting up the system I tried to create the same ssid name as my old system which included a ‘ orbi setup says I can’t use this. So that means all my LIFX lightbu...
Apr 05, 2018Guru - Experienced User
This an Apostrophy? ( ' )
Maybe some thing NG doesn't support on the Orbi system. i usually don't use specialized characters in SSID names. Maybe a ( - ) dash is all.
You might ask NG support over phone weather they support that character or not.
- rugbydmanApr 05, 2018Aspirant
if i change ssid i have to hard reset too many things
