rugbydman
Apr 05, 2018Aspirant
SSID Naming
Hi. I just got my orbi rbk50. When setting up the system I tried to create the same ssid name as my old system which included a ‘ orbi setup says I can’t use this. So that means all my LIFX lightbu...
Apr 05, 2018Guru - Experienced User
This an Apostrophy? ( ' )
Maybe some thing NG doesn't support on the Orbi system. i usually don't use specialized characters in SSID names. Maybe a ( - ) dash is all.
You might ask NG support over phone weather they support that character or not.
rugbydman
if i change ssid i have to hard reset too many things
- FURRYe38Apr 05, 2018Guru - Experienced User
Well for short term, you may have to. If this is something NG may fix, if they do, will take a while.
You'll have to contact NG support about this.
- rugbydmanApr 06, 2018Aspirant
Hi. Does anyone know if the latest update solves this problem
- Retired_MemberApr 06, 2018
I would doubt it. NG seems to be more focused on all the cool things people complaint about, like;
back haul
AP mode
Disney/circle
device list
etc.
