Kimhe
May 28, 2020Aspirant
SSID password missing
on satellite or the router there is no SSID password label. only serial number and MAC number. How to password in ordet to get connected ?
Sort By
What model Orbi system do you have? 1, 20, 40 or 50 series?
Just press the sync button on the RBR then on the RBS. The satellite will sync to the RBR and acquire the same log in name and password from the RBR.
- KimheAspirant
RBK13 AC1200 dual-band Mesh. Bought from Amazon used one.
I did reset router but no luck. There is no SSID label and password. How to get it connected that is mystery. Asking password but there is not that label on the cubes.
Did you walk thru the setup wizard with a wire connected PC and web browser?
Review the installation guide or user manual for installation instructions and help.
The cubes will not have a password until they are synced to the main RBR unit.
