ALNJ2017
Jan 25, 2018Star
Stability AP vs Router mode on .18 release
Does anyone have experience with moving the Orbi to AP mode on the .18 release ? Wondering if that is a temporary way to get some atability. Just need a spare box for Router/NAT/DHCP. any rec...
- Jan 29, 2018
Ok will try setup as AP.
Den_
Jan 25, 2018Guide
I updated my Orbi to .18 yesterday. I run it on AP mode and before the update it would reset every few hours. Since the .18 update it has not reset once (just over 24h). I will keep an eye on it, but it seems a lot more stable. Also my Samsung galaxy s8 used to get authentication errors daily. I haven't had one of those either. I know it's not been running long, but it is a big improvement over all the other versions I have tried.
