BrentATX
Jan 22, 2019Aspirant
Stability issue
Orbi system is dropping about every 20mins. I've seen a number of posts here with help provided, but also have read different solutions. I've tried some of them and still am having troubles. Inte...
BrentATX
I am within the 30ft recommend. I have the modem set as passthrough. The Orbi router and modem are about 4 inches apart :smileyvery-happy:
dumb question: steps to check Orbi for channel 11?
Shotround
Jan 22, 2019Apprentice
im on att uverse but with internet/dsl only using a pace gateway. i think im on to something if you can check these settings out. might be different with your device. i changed my tcp session timeout to 1800 seconds for now. restart the gateway/modem if you change that setting. i have written up my findings but need a few more days to verify.
a. pace gateway -> settings -> diagnostics -> nat -> total sessions in use around 6000 or about 75%
b. pace gateway -> firewall -> advanced configuration -> tcp session timeout at 86400 seconds (default)
