ryanadams23
Jan 04, 2018Aspirant
Stalled Wifi - and Slow Speeds
I just recently purchased this RBK50 Orbi System. I tested the speeds in the house and it has done much better than previous Apple System. Here's my setup: House: 3900 Sqft - 2 stories. ...
ryanadams23
2.0.0.74
aaz
Jan 04, 2018Virtuoso
Well, I have to say I have not seen it on that firmware. I'd try running speedtest to see what you are getting from various devices. If you are comfortable enough with manual updates I would say try the new 2.1.2.10 firmware - I can only say that it's been stable for the last 24 hours, but cannot say how it would affect you.
If you want to remain on .74 for now, maybe try cold rebooting your routers and satellites using the switch. How long have you been running .74 before you noticed an issue?
