Jdoftx
Feb 27, 2020Follower
Standard Parental Controls. Open DNS parental controls.
I have the standard parental control turned on with open dns. I can't shop at this site. https://www.victoriassecret.com Anyway to unblock it?
CrimpOn
Feb 27, 2020Guru - Experienced User
Well, the obvious thought is to (a) turn off Parental Controls, (b) do your shopping, and (c) turn Parental Controls back on.
However.....
I have never activated Parental Controls, so I did so just now. ("Standard", not "Disney"). Clicked "Apply" and then opened the web site with two different browsers. (victoriassecret.com) So, activating Standard Parental Controls did NOT block this web site for me. (Nor did it block some rather obvious porn web sites, but that's another story.)
I found it rather frustrating when I clicked on the Orbi link "Learn More" under Standard Parental Controls and it took me to the Disney Circle information (not to Standard Parental Controls). I have this suspicion that "Standard Controls" no longer exists?
Anyway, Good Luck!
Ergates
Apr 19, 2020Aspirant
Hmm.. same here :smileyfrustrated:
