brucewol12
Sep 25, 2022Aspirant
starlink static routing
I'm new to starlink and saw references to set up static routing, so tried it. i've got a gen 2 dishy and operate with the internet adapter and starlink in pass through mode. for me the statistic tap ...
- Sep 26, 2022
What Orbi model do you have.
Contact Starlink for additional help and support of there services and configurations.
brucewol12
Sep 26, 2022Aspirant
I've got an orbirb50 with 1 satellite. starlink support rarely responds with anything useful, found it better to post on forums. in any case, i'm returning starlink after about a week trying to get it to be viable. after testing it standalone outside and getting 50 mb during the day, i went ahead and started a permanent routing of the cable to the dish. then i found out i often was only getting 3 - 8 mb during the evening hours 6 - 10 pm. starlink has been oversold and satellite deployment delayed, so it will be awhile before there is a fix.
thanks for your response.
Sep 26, 2022Guru - Experienced User
Good Luck.
