BrettStark
Dec 21, 2020Aspirant
Static IP address - DNS Failing - Obi RBR50 with 2 satellites
Hello - I tried to set a static IP address for a raspberry pi 3b+. Tried on the client (dh....conf file - ie instructions here https://www.raspberrypi.org/documentation/configuration/tcpip/) and ass...
BrettStark
Hi Yes, that was what i was trying to do to setup pihole.... i found i can't even ping to an IP address either! But, I am connected on wi-fi.. the pi shows as a client in the orbi client list..
CrimpOn
Dec 21, 2020Guru - Experienced User
I set my Pi's up as "headless" and use PuTTY to SSH into them for management (or VNC for graphic interface).
Does this Pi have a keyboard/display or it is headless?
By any chance is Access Control enabled on the Orbi?
- BrettStarkDec 22, 2020Aspirant
access control disabled.
i use headless too but for now just have a kb/mouse attached.
