RavetheDave
Apr 22, 2020Aspirant
Static ip
Hi I have the RBR50 and RBR50S and I Ethernet from the satellite to my PS4 but I keep getting lan cable disconnected which I have read is an issue with the PS4, most suggestions are to give the PS4 a...
Apr 22, 2020Guru - Experienced User
Static IP addressing is set ON devices.
Reserved IP addressing is set ON the router.
You can set a IP address reservation for the PS on the RBRs web page under Advanced Tab/Setup/LAN Setup.
Have the PS connected and ON and it will appear in the ADD IP address reservation list. Select this device, edit the device name, then select ADD then APPLY. The RBR will reboot.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
