chickenfrog
Apr 21, 2017Follower
Static Routing and NAT (iptables)
******* I'm posting this as a reference. I struggled with this for about a day, trying to untangle the iptables of my Netgear Orbi. Maybe this write-up can help others. USE AT YOUR OWN RISK Th...
TheEther
Sep 23, 2017Guru
Very clever!
fabbari
Sep 23, 2017Tutor
I updated the script to make sure we logout any admin using the web-interface. It may be an inconvenience when an admin is using the web interface, but ensures that automated scripts will always run successfully.
#!/bin/sh
# NOTE: This script requires openssl and the real netcat to be available, not the BusyBox version. On OpenWRT
# you can get them via:
# opkg install netcat openssl-util
ORBI_USERNAME="admin"
ORBI_PASSWORD="*********"
ORBI_ADDRESS="192.168.1.1"
AUTH_TOKEN=`echo -n "${ORBI_USERNAME}:${ORBI_PASSWORD}" | openssl enc -base64`
function forceLogout() {
curl -s "https://${ORBI_ADDRESS}/change_user.html" -H "Authorization: Basic ${AUTH_TOKEN}" --insecure > /dev/null
function timeStamp() {
curl https://${ORBI_ADDRESS}/debug_detail.htm -s --insecure -H "Authorization: Basic ${AUTH_TOKEN}" | grep -e '^var ts' | sed -e 's/var\W\+ts="\([^"]\+\)".*/\1/g'
function enableTelnet() {
TS_CODE=`timeStamp`
curl "https://${ORBI_ADDRESS}/apply.cgi?/debug_detail.htm%20timestamp=${TS_CODE}" -H "Authorization: Basic ${AUTH_TOKEN}" --data 'submit_flag=debug_info&hid_telnet=1&enable_telnet=on' --insecure -s > /dev/null
function disableTelnet() {
TS_CODE=`timeStamp`
curl "https://${ORBI_ADDRESS}/apply.cgi?/debug_detail.htm%20timestamp=${TS_CODE}" -H "Authorization: Basic ${AUTH_TOKEN}" --data 'submit_flag=debug_info&hid_telnet=0&enable_telnet=off' --insecure -s > /dev/null
function isForwarding() {
RULE=`(echo "iptables -L --line-numbers"; sleep 2) | netcat -c -t ${ORBI_ADDRESS} 23 | grep '^5\W\+DROP\W\+all\W\+--\W\+!\d\+\.\d\+\.\d\+\.\d\+\/\d\+\W\+anywhere'`
if [ "${RULE}" = "" ]
then
echo "Forwarding enabled"
else
echo "Forwarding disabled"
fi
function enableForwarding() {
FORWARD=`isForwarding`
if [ "${FORWARD}" = "Forwarding disabled" ]
then
echo "Enabling forwarding - current state: ${FORWARD}"
(echo "iptables -t filter -D loc2net 5 && iptables -t nat -I POSTROUTING 1 -o brwan -j MASQUERADE"; sleep 1) | netcat -c -t ${ORBI_ADDRESS} 23 > /dev/null
isForwarding
else
echo "Forwarding is already enabled!"
fi
case "$1" in
enable)
forceLogout
enableTelnet
disable)
forceLogout
disableTelnet
check)
forceLogout
enableTelnet
isForwarding
disableTelnet
forward)
forceLogout
enableTelnet
enableForwarding
disableTelnet
echo ""
echo "$0 [enable|disable|forward]"
echo ""
echo " enable: enable Orbi telnet interface"
echo " disable: disable Orbi telnet interface"
echo " check: check if Orbi is forwarding internal networks"
echo " forward: allow Orbi to forward internal networks"
echo ""
esac- fabbariSep 23, 2017Tutor
Last version of this script - I promise! Quick instructions: install socat, netcat and openssl-util on your openwrt router. Drop the script in a file called `/etc/init.d/orbi` - make the file executable. Edit the file to change your password and Orbi IP address - if it's not 192.168.1.1. Then enable the script: `/etc/init.d/orbi enable' and start it: '/etc/init.d/orbi start'.
The script will listen for multicast messages from Orbi - every time it will detect one, it will check if the Orbi is configured for forwarding the internal lan - sleep for 30 seconds and start listening again.
Let me know if anyone finds this useful.
Fabio
#!/bin/sh /etc/rc.common # Example script # Copyright (C) 2007 OpenWrt.org START=10 STOP=15 # NOTE: This script requires socat, openssl and the real netcat to be available, not the BusyBox version. On OpenWRT # you can get them via: # # opkg install socat netcat openssl-util # ORBI_USERNAME="admin" ORBI_PASSWORD="*************" ORBI_ADDRESS=192.168.1.1 ORBI_MCAST_PORT=5353 ORBI_MCAST_ADDR=224.0.0.251 ORBI_MCAST_IF=eth0.2 AUTH_TOKEN=`echo -n "${ORBI_USERNAME}:${ORBI_PASSWORD}" | openssl enc -base64` ORBI_SCRIPT=/etc/init.d/orbi function forceLogout() { curl -s "https://${ORBI_ADDRESS}/change_user.html" -H "Authorization: Basic ${AUTH_TOKEN}" --insecure > /dev/null curl -s "https://${ORBI_ADDRESS}/change_user.html" -H "Authorization: Basic ${AUTH_TOKEN}" --insecure > /dev/null } function timeStamp() { curl https://${ORBI_ADDRESS}/debug_detail.htm -s --insecure -H "Authorization: Basic ${AUTH_TOKEN}" | grep -e '^var ts' | sed -e 's/var\W\+ts="\([^"]\+\)".*/\1/g' } function enableTelnet() { TS_CODE=`timeStamp` curl "https://${ORBI_ADDRESS}/apply.cgi?/debug_detail.htm%20timestamp=${TS_CODE}" -H "Authorization: Basic ${AUTH_TOKEN}" --data 'submit_flag=debug_info&hid_telnet=1&enable_telnet=on' --insecure -s > /dev/null } function disableTelnet() { TS_CODE=`timeStamp` curl "https://${ORBI_ADDRESS}/apply.cgi?/debug_detail.htm%20timestamp=${TS_CODE}" -H "Authorization: Basic ${AUTH_TOKEN}" --data 'submit_flag=debug_info&hid_telnet=0&enable_telnet=off' --insecure -s > /dev/null } function isForwarding() { RULE=`(echo "iptables -L --line-numbers"; sleep 2) | netcat -c -t ${ORBI_ADDRESS} 23 | grep '^5\W\+DROP\W\+all\W\+--\W\+!\d\+\.\d\+\.\d\+\.\d\+\/\d\+\W\+anywhere'` if [ "${RULE}" = "" ] then FORWARDING=1 else FORWARDING=0 fi } function enableForwarding() { isForwarding if [ ${FORWARDING} -eq 0 ] then logger -t ORBI -p daemon.info "Enabling forwarding" (echo "iptables -t filter -D loc2net 5 && iptables -t nat -I POSTROUTING 1 -o brwan -j MASQUERADE"; sleep 1) | netcat -c -t ${ORBI_ADDRESS} 23 > /dev/null else logger -t ORBI -p daemon.warn "Forwarding is already enabled!" fi } EXTRA_COMMANDS="on off forward check monitor" EXTRA_HELP=<<EOF on Enable telnet on the Orbi off Disable telnet on the Orbi forward Manually enable forwarding for the Orbi check Check the Orbi to see if forwarding is enabled monitor Enable monitoring of Orbi EOF start () { logger -t ORBI -p daemon.info 'Launching background monitor' (( ${ORBI_SCRIPT} monitor >/dev/null 2>&1 ) & ) & } stop () { if [ -f /tmp/.orbi.running ] then logger -t ORBI -p daemon.info 'Stopping Orbi Service' PID=`cat /tmp/.orbi.running` rm /tmp/.orbi.running kill -TERM ${PID} else logger -t ORBI -p daemon.info 'Orbi Service not Running' fi } restart () { stop sleep 1 start } monitor() { logger -t ORBI -p daemon.info 'Starting Orbi Monitor Service' echo $$ > /tmp/.orbi.running while [ -f /tmp/.orbi.running ] do socat UDP4-RECV:${ORBI_MCAST_PORT},bind=${ORBI_MCAST_ADDR},ip-add-membership=${ORBI_MCAST_ADDR}:${ORBI_MCAST_IF},range=${ORBI_ADDRESS}/32 SYSTEM:"${ORBI_SCRIPT} forward" sleep 30 done logger -t ORBI -p daemon.info 'Orbi Monitor Service Exited' } on () { forceLogout enableTelnet } off () { forceLogout disableTelnet } check () { forceLogout enableTelnet isForwarding if [ ${FORWARDING} -eq 0 ] then echo "Forwarding is disabled" else echo "Forwarding is enabled" fi disableTelnet } forward () { if [ -f /tmp/.orbi.enabling ] then logger -t ORBI -p daemon.warn "Already enabling Orbi forwarding - Ignoring request" else touch /tmp/.orbi.enabling forceLogout enableTelnet enableForwarding disableTelnet rm /tmp/.orbi.enabling fi }
