GTPprix
Mar 06, 2018Star
Status is showing BOTH Satellites as Wired Backhaul when only one is?
Not that this is a big performance issue since they DO work but long story short I've got two of the full size satellites. One is upstairs and is indeed Ethernet Backhauled the other is in my basemen...
Mar 06, 2018Guru - Experienced User
Let us know if this changes anything:
https://community.netgear.com/t5/Orbi/Router-solid-Magenta-in-AP-Mode-Fix-yet
- GTPprixMar 06, 2018Star
If you're referring to plugging into the WAN port that wont work in my setup as the Router (In AP Mode) is plugged right into a switch not a WAN device.
