GodJero
Sep 25, 2017Aspirant
Statut satelitte grisé
Bonjour, Sur la page web du satellite, à l'affichage du statut, j'ai la partie 5GHz qui est grisée, est-ce normal (cf. fichier joint)? Cependant, le ou les devices connectés en 5GHz fonctionnent ...
GodJero
- Version Matérielle: RBS50
- Version du firmware: V2.0.0.72
- GodJeroSep 26, 2017Aspirant
My mystake...I wrote in French...
Hello,
On the satellite web page, on the status display, I have the 5GHz part which is grayed out, is this normal (see attached file in the first message)? However, the device (s) connected in 5GHz is working correctly.
Thank you in advance for your advice. Rgds.- martyfpSep 26, 2017Luminary
No, it is not normal... You might want to look at this thread :
https://community.netgear.com/t5/Orbi/Satellite-connected-to-2-4-Ghz-not-5-Ghz/m-p/1337979#M11424
Hello,
Many thx for this link, I unchecked the “Enable Daisy-Chain Topology”, now the 5GHz link is orange and the satellite blackhaul is on the 5G.
I don't understand why the 2.4 G is in blue and the 5G in orange...any idea ?
Thx and rgds.Jerome.
