stevei1940
Mar 20, 2024Aspirant
Steps to Install an additional RBR 50 to an existing RBR 50 system
I need to add an additional RBR 50 to an existing RBR 50 system for additional coverage. What steps do I need to take to install it?
- Mar 21, 2024
Now that so many phones, tablets, laptops support WiFi6, replacing a WiFi5 system with WiFi6 (or even WiFi6E) is a common move. The good news is that every major WiFi vendor sells capable products. (The bad news is also that every major vendor has good products, so making a choice becomes more complicated.)
CrimpOn
Mar 20, 2024Guru - Experienced User
Netgear's Orbi products have two distinct models:
- Router, such as RBR50
- Satellite, such as RBS50
Unlike some other companies, Netgear designed the Orbi line where there is one "router" and a variable number of "satellites". There cannot be multiple routers. Thus, Step 1 is purchase an RBS50.
Once the satellite is on hand, plug it into power close to the router (so that it is easy to observe and manipulate both units).
Then Step 2 is to use the Orbi 'app' or the Orbi web interface to Add a satellite. (I much prefer the web interface). See page 12 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Step 3 is to relocate the satellite to the desired location which is close enough to the router to get a "Good" connection (indicated by the ring light on the top turning Blue for 3 minutes) and far enough away to expand the WiFi coverage area as desired.
