stevei1940
Mar 20, 2024Aspirant
Steps to Install an additional RBR 50 to an existing RBR 50 system
I need to add an additional RBR 50 to an existing RBR 50 system for additional coverage. What steps do I need to take to install it?
- Mar 21, 2024
Now that so many phones, tablets, laptops support WiFi6, replacing a WiFi5 system with WiFi6 (or even WiFi6E) is a common move. The good news is that every major WiFi vendor sells capable products. (The bad news is also that every major vendor has good products, so making a choice becomes more complicated.)
stevei1940
Mar 21, 2024Aspirant
Thanks so much for this. I mistakenly bought the wrong model. I bought the RBR 50.
Can I use it as a satellite?
Mar 21, 2024Guru - Experienced User
No, only as a router or in AP mode.
- stevei1940Mar 21, 2024Aspirant
What is AP mode? Please explain. Thanks.
- FURRYe38Mar 21, 2024Guru - Experienced User
Mainly the router portion of the RBR is disabled and only the Wi-Fi system is used for connections with Wi-Fi devices. Has to be ethernet connected to a host router when in AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Unless there's another workaround, it looks like I wasted some money. I can't get an ethernet cable from the router to connect the new device. It's way too far.
