sixthnewkid
Nov 24, 2019Follower
Stop from connecting to 2.4ghz and selecting wrong satellite RBK50
BIg disappointment after getting really slow speeds compared to my google wifi router. I purchased this for my sons computer which is in an adjacent room from the main router. It always connects to...
michaelkenward
Nov 26, 2019Guru - Experienced User
Does this mean that you have two routers?
If so, that's a good way to mess up your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
