beckss1
Jun 06, 2019Tutor
Strange behaviour RBW30
Dear comminity forum., I have RBR40 + RBW30 Orbi system and in past when I have problems with sattilite disconnected I downgrade it to low version and upgrade it back. Yesterday I downgraded manu...
Jun 07, 2019Guru - Experienced User
Try a full factory reset on the entire system then setup from scratch. If you revert back to older FW versions, then auto updates may still happen.
- beckss1Jun 11, 2019Tutor
Hi.,
Thanks for you answer, but I don't downgrade router. Only sattelite I did.
Best regards,
