beckss1
Jun 06, 2019Tutor
Strange behaviour RBW30
Dear comminity forum., I have RBR40 + RBW30 Orbi system and in past when I have problems with sattilite disconnected I downgrade it to low version and upgrade it back. Yesterday I downgraded manu...
Jun 07, 2019Guru - Experienced User
Try a full factory reset on the entire system then setup from scratch. If you revert back to older FW versions, then auto updates may still happen.
beckss1
Jun 11, 2019Tutor
Hi.,
Thanks for you answer, but I don't downgrade router. Only sattelite I did.
Best regards,
