nailman107
Aug 24, 2020Aspirant
Strange Daisy Chain order on my RBK53 set
Hi, I had to re-position my Orbis to cover not only the full house area but also the garage and garden. The Orbi router and three satellites have arranged themselves for this order: The router (...
- Aug 24, 2020
The satellites should self-regulate and connect to each other to provide the "strongest" signal. First, be certain all the satellites and the router have the EXACT same firmware installed. One of the current issues is the reporting of daisy chain connections tends to be "off", i.e., the satellites take a long time to settle and may change their connection reporting frequently. The smartphone app can also show a different status than the built-in browser GUI.
If you are getting "Poor" connections reported, I suggest you tell the router to remove all three satellites and power down the satellite. Then power the satellites up–one at a time–starting with the closest one. Then reconnect/resync that one. Allow it several minutes (15-20) to establish a "Good" reported connection. Then go to the next satellite in the chain and repeat until all three are back online and reporting "Good".
After allowing this "new" system at least 12 hours to settle, if the backhaul status stills shows "Poor" I suggest changing the location of the satellites to achieve a "Good" backhaul signal. Good luck!
tucsontico
Aug 24, 2020Virtuoso
nailman107
Ok, thank you all. I'll try playing around with the locations and power down and up again as suggested. Best regards
Michael
- MstrbigAug 24, 2020Master
nailman107 wrote:Ok, thank you all. I'll try playing around with the locations and power down and up again as suggested. Best regards
Michael
You basically have to ignore the distance factor when setting up the Satellites. There are more factors, such as walls, interference, floors, etc. And it's better to set them up one at a time in the same room as the Router, then one by one move them to their designated locations.
