jerrremy
Sep 24, 2019Aspirant
Strange issues with Orbi RBR50 apps and websites
Hi there, I've had this router for about a year and it's been working fine, but I've recently started running into some really strange issues. When using my mobile phone connected to WiFi, I ...
Sep 25, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jerrremy wrote:Hi there,
When using my mobile phone connected to WiFi, I can't access certain websites and some apps just don't work - specifically, all Google searches, Facebook, Instagram, and a few others. These websites work fine on all computers connected to the same WiFi network. These apps/websites work on other WiFi networks with the same phone with no issues. I have also tried connecting other mobile phones (both iPhone and Android) to my network and all experience the same issues.
I have the router connected to the router provided by my ISP that's set to bridge mode. I'm using the Orbi RBR50 router with one satellie connected and both are on firmware 2.3.5.30 .
Any help troubleshooting this would be hugely appreciated.
Thanks in advance!
- jerrremyOct 20, 2019Aspirant
Hello! Thanks for responding. The modem is an Actiontec T3200M, relabelled as a Telus modem (I'm in Calgary, Alberta, Canada). Link below:
https://www.actiontec.com/products/wifi-routers-gateways/vdsl/t3200m/
I set it to bridge mode and all wifi signals are turned off, but maybe there are additional settings I need to change. Any ideas?
Thanks again!
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Thanks in advance!
- ekhalilOct 21, 2019Master
jerrremy wrote:.......
What DNS settings do you have in Orbi?
If set to get autmatically from ISP, can you please test to change to manual DNS and try 8.8.8.8 and 8.8.4.4 instead, and see if this will make any difference.
Thank you
