jerrremy
Sep 24, 2019Aspirant
Strange issues with Orbi RBR50 apps and websites
Hi there, I've had this router for about a year and it's been working fine, but I've recently started running into some really strange issues. When using my mobile phone connected to WiFi, I ...
dkkruse
Sep 25, 2019Aspirant
I have the same strange issue with my RBR50 which is only in AP mode with my Verizon Fios Quantum Gateway router. FB, Instagram don't work, and then do when I turn off Wifi. I'm also having the solid Purple Ring on my router and can't login...
Sep 25, 2019Guru - Experienced User
Have you set up a reserved IP address on the FIOS router for the RBR?
Is the RBR connected to the FIO router using the WAN port on the RBR?
Ensure the RBR is in AP mode.
Swap LAN cables between the FIOS router and RBR.
dkkruse wrote:I have the same strange issue with my RBR50 which is only in AP mode with my Verizon Fios Quantum Gateway router. FB, Instagram don't work, and then do when I turn off Wifi. I'm also having the solid Purple Ring on my router and can't login...
