Docgil
Feb 10, 2018Aspirant
Strange or not? Two LAN on same Orbi?
I have rbk50 and installed them correct. But I find it a bit strange that I can access my primary router using borth 192.168.0.1 and 192.168.1.1. Is this a faulty setup or is my router operating om b...
st_shaw
Feb 10, 2018Master
wrote:
I have rbk50 and installed them correct. But I find it a bit strange that I can access my primary router using borth 192.168.0.1 and 192.168.1.1. Is this a faulty setup or is my router operating om both LAN levels? When entring my router using 1.1, I can see it the setup page that I have sat internal LAN to be 0.1. Should it be like this? I just think it is strange...2,4/5 thing?
It should not behave this way. Something is probably misconfigured.
You refer to your "primary router". Do you have other routers on your LAN. If so, that could be causing your issue.
On Orbi's LAN setup, make sure you are using the correct settings:
LAN IP address. 192.168.0.1
Subnet mask. 255.255.255.0
- DocgilFeb 10, 2018Aspirant
Hi
I have one rbr50 and two rbs50 sat. The fiber modem is bridged. I do not have any other routers and I like to think I am pretty good in setting up a network. I am entering the same rbr50 using both ip-addresses. That is what I find so strange.
