Docgil
Feb 10, 2018Aspirant
Strange or not? Two LAN on same Orbi?
I have rbk50 and installed them correct. But I find it a bit strange that I can access my primary router using borth 192.168.0.1 and 192.168.1.1. Is this a faulty setup or is my router operating om b...
st_shaw
Feb 10, 2018Master
wrote:
I have rbk50 and installed them correct. But I find it a bit strange that I can access my primary router using borth 192.168.0.1 and 192.168.1.1. Is this a faulty setup or is my router operating om both LAN levels? When entring my router using 1.1, I can see it the setup page that I have sat internal LAN to be 0.1. Should it be like this? I just think it is strange...2,4/5 thing?
It should not behave this way. Something is probably misconfigured.
You refer to your "primary router". Do you have other routers on your LAN. If so, that could be causing your issue.
On Orbi's LAN setup, make sure you are using the correct settings:
LAN IP address. 192.168.0.1
Subnet mask. 255.255.255.0
Docgil
Hi
I have one rbr50 and two rbs50 sat. The fiber modem is bridged. I do not have any other routers and I like to think I am pretty good in setting up a network. I am entering the same rbr50 using both ip-addresses. That is what I find so strange.
- st_shawFeb 10, 2018Master
OK. Did you check the Orbi GUI to see what the LAN IP and subnet mask settings are?
- DocgilFeb 10, 2018Aspirant
The LAN setting show:
IP address: 192.168.0.1
ip sub net: 255.255.255.0
Ok. Strange. It is permissible for one device (i.e. Orbi) to maintain more than one IP address, so technically what you are seeing is not invalid. Many devices retain a permanent IP address so they can be accessed if something is misconfigured, and 192.168.1.1 is the default address for the Orbi router. I just haven't heard of Orbi retaining that address.
Check the WAN IP address of Orbi. Is it a valid public WAN IP, or a private IP address like 10.0.0.X?
What are the IP and subnet mask settings on the client device you are using to access Orbi?
You could try powering off your router and any switches you have on the network, then turning everything back on.
If that doesn't work, I would try changing Orbi's LAN address to something different, like 192.168.2.1, to see if that resolves the issue.
