irwando
Apr 12, 2018Aspirant
Streaming Blu-Ray video over Orbi (hardwired) - Errors
Hey all, I have an RBK50 system with router + 1 sattellite. These are connected via a cat 5e hardwired cable across my house. On the main router I have a Synology NAS device plugged in with...
Apr 12, 2018Guru - Experienced User
Was a factory reset performed after updating the FW? This needs to be done for this version of FW.
Where are the NAS and BD player connected? Behind the router or behind the Sat?
Any Network switches in between the router and satellite? Mfr and model#?
What kind of MKV files and resolution are these files? High bandwidth? High resolution?
Try disabling MIMO, Daisy Chain, Fast Roaming and 20/40Mhz Coexistence...
irwando
Apr 13, 2018Aspirant
I don't think i ever did the factory reset, I'll try that! Can i just restore settings from a backup after that?
NAS is connected tot he router, blu-ray is connected to the satellite. Everything is hard wired (including the backhaul). No switches.
The MKV's are full audio/video bitrate for blu-ray as I don't compress them at all.
