irwando
Apr 12, 2018Aspirant
Streaming Blu-Ray video over Orbi (hardwired) - Errors
Hey all, I have an RBK50 system with router + 1 sattellite. These are connected via a cat 5e hardwired cable across my house. On the main router I have a Synology NAS device plugged in with...
Apr 13, 2018Guru - Experienced User
Try a reset and set up from scratch. Run a quick test to see if streaming problem is resoved before applying last saved configuration.
Possible that the bandwidth of these files could be too high going from Satellite to NAS.
I would run a test as well and connect the player to the back of the router or vs versa, connect NAS to satellite with player and test.
- irwandoApr 13, 2018Aspirant
Thanks.
This was all working fine before my switch to an Orbi based system, so if its too much for Orbi, I guess I'm abandoning ship.
- FURRYe38Apr 13, 2018Guru - Experienced User
let us know how it does after reset.
I have a similar set up however my streaming device and NAS are on the LAN side connect via Gb switch and not between the Satellite and router. I do have a wireless bridge connected to the Satellite which services a DISH Joey. Streams video fine there however the bandwidth I presume is way smaller than raw BD data.
- irwandoApr 14, 2018Aspirant
I did a "factory reset" via the web UI and still experienced issues. However, reading more, perhaps I need to do a paper-clip resent on the satellite and router seperately?
For fun I unplugged the backhaul cable from the satellite and plugged it directly into the Blu-Ray player (so essentially the Blu_Ray and NAS are both hard-wired into the router). 1+ hour of movie and no pauses yet.
