irwando
Apr 12, 2018Aspirant
Streaming Blu-Ray video over Orbi (hardwired) - Errors
Hey all, I have an RBK50 system with router + 1 sattellite. These are connected via a cat 5e hardwired cable across my house. On the main router I have a Synology NAS device plugged in with...
eljarviso
Apr 22, 2018Luminary
What model of Synology NAS? I have a synology DS416Play and had the EXACT same issue as you. My NAS has two network interfaces and I had them setup in a load balancing bridge (the automatic method that synology says doesn't require 802.1q trunking). This worked perfectly with my previous ASUS router but when connected to the Orbi caused pausing/skips in MKV playback. I had to remove the bridge and run the NAS on only one interface. The Orbi has issues with bridged interfaces.
- irwandoApr 22, 2018Aspirant
Synologoy Diskstation 412+. Only one network interface is even connected, so definitely not bridged.
- eljarvisoApr 22, 2018LuminaryDoing the iperf will let you know if it’s a bandwidth issue. I also recommend doing an ssh into your NAS and doing a ping against your oppo. This will check for packet loss. Is your satellite using wired or wireless backhaul?
Wired backhaul. If I plug the backhaul line directly into the Oppo it works flawlessly.
Thanks for the iPerf hint. I ran it 2x, once hardwired into the satellite, once hardwired into the router. No meaningful differences I can see. Results attached.
