poswald
Nov 18, 2018Guide
Streaming from network devices stops due to constant DHCP lease renewal?
I've had nothing but trouble with the orbi system but mostly we have battled to a stalemate. The one remaining thing I can't tolerate is constant dropping of streams from Apple TV, Amazon Fire sticks...
ekhalil
Nov 20, 2018Master
poswald wrote:
It seems to be caused by reissuing IP addresses. For example I constantly get ‘Lost internet connection’ on the 4th gen Apple TV even if it isn’t playing anything. When It's playing music then it drops the stream and stops. Pressing play immediately starts it again without delay.. it's not an internet problem, it's a local network issue. It’s accompanied by a log entry on the Orbi:
- [DHCP IP: 10.0.0.8] to MAC address xxxxxx, Sunday, October 14, 2018 09:59:41
Do you notice that those devices change from 2.4GHz to 5GHz or vice versa when this interruption happens?
I noticed that some of my devices suddenly decide to move between the two bands back and forth, together with this change there will be internet interruption for a short period and a DHCP message like the one you mentioned in the Logs.
- lizabnyNov 20, 2018Aspirant
I am seeing the same exact issue - with constant dhcp ip issuing and clients continuously dropping from the network. And my newest macbook pro willl not reconnect, and occassionally other macbooks, iphones and ipads suffer the same issue. We don't have many heavily used, non-ios clients, but my canon printer hasn't been able to be used without restarting it, either. I've also tried all sorts of various options and placements, and am stuck, and frustrated because it disrupts business video calls and demos all the time! We have a 5000 sqft home and have tried R-S-S daisy chain and S-R-S configurations, with no improvement. I'll have a day or two with no issues, and then mornings like just now where it dropped almost a dozen times within an hour.
I do notice that sometimes I'm connected to 2.4 and sometimes 5, though I don't know if it constantly flip-flops back and forth. I'll watch for that. Maybe I'll try to force the 5 connection only either through the clients or the router, and see if that stabilizes things.
- FURRYe38Nov 20, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually for R-S-S.
FURRYe38 wrote:
V2.2.1.210What FW is currently loaded?
ISP is Spectrum Charter, and modem is Arris T1602AWhat is the Mfr and model# of the ISP modem the NG router is connected too?
router to sat1 is 57', router to sat2 is 42', sat1 to sat2 is 52 - I've tried several different configs, this is just where they're at right now.
auto on 2.4, and 48 on 5. mac scan shows 11 is best for 2.4 and it is currently on 8, so I'll change that. 161 is best for 5, but that's not an option through the ui, and I haven't been able to telnet in to change it as instructed in some post.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Of course, yes. My strongest RSSI via the mac scan comes in at -74 and shows three bars where I am scanning from in my office. There are seven others, strongest at -85 (two bars), weakest at -94 (one bar).
done (noting that ipv6 was already disabled, and based on note below and that I'm on .210, I left daisy chain enabled) I'll check back in a day or so with updates on these settings.Try disabling the following and see:
I'll run this for a day or so, and may switch daisy chain to see if that helps/hurts. ditto for fast roaming.If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually for R-S-S.
I've also been reading and trying the things at https://windsorwebdeveloper.com/making-netgear-orbi-great-again/ up to this point, and have dropped the 2.4 signal to 25% (I want to discourage 2.4 swapping) and 5 to 75%. And I've set my mac network hardware mtu to 1453. I may stop making so many changes or reset and do some things one at a time, if I have time to further troubleshoot once the system is stable.
Thank you for your help!
