poswald
Nov 18, 2018Guide
Streaming from network devices stops due to constant DHCP lease renewal?
I've had nothing but trouble with the orbi system but mostly we have battled to a stalemate. The one remaining thing I can't tolerate is constant dropping of streams from Apple TV, Amazon Fire sticks...
lizabny
Nov 20, 2018Aspirant
FURRYe38 wrote:
V2.2.1.210What FW is currently loaded?
ISP is Spectrum Charter, and modem is Arris T1602AWhat is the Mfr and model# of the ISP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.router to sat1 is 57', router to sat2 is 42', sat1 to sat2 is 52 - I've tried several different configs, this is just where they're at right now.
auto on 2.4, and 48 on 5. mac scan shows 11 is best for 2.4 and it is currently on 8, so I'll change that. 161 is best for 5, but that's not an option through the ui, and I haven't been able to telnet in to change it as instructed in some post.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Of course, yes. My strongest RSSI via the mac scan comes in at -74 and shows three bars where I am scanning from in my office. There are seven others, strongest at -85 (two bars), weakest at -94 (one bar).
done (noting that ipv6 was already disabled, and based on note below and that I'm on .210, I left daisy chain enabled) I'll check back in a day or so with updates on these settings.Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I'll run this for a day or so, and may switch daisy chain to see if that helps/hurts. ditto for fast roaming.If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually for R-S-S.
I've also been reading and trying the things at https://windsorwebdeveloper.com/making-netgear-orbi-great-again/ up to this point, and have dropped the 2.4 signal to 25% (I want to discourage 2.4 swapping) and 5 to 75%. And I've set my mac network hardware mtu to 1453. I may stop making so many changes or reset and do some things one at a time, if I have time to further troubleshoot once the system is stable.
Thank you for your help!
poswald
Nov 20, 2018Guide
lizabny, ekhalil:
Thanks for replying and sorry you're seeing it too.. you're both describing 2.4GHz to 5GHz changes but I actually now suspect it's the router deciding to go from 20Mhz wide bands to 40Mhz wide bands and vice versa within the 2.4GHz network. Usually, 40Mhz wide bands are a bad idea in a crowded Wifi environment. What netgear seemingly is doing is looking for noise and if it sees a network nearby it switches to the more narrow 20MHz band. It could also be both 20<->40Mhz switching and 2.4<->5GHz switching though... who knows. Part of the problem is that the orbi doesn't actually log enough about what it's actually doing to be able to know.
There is a setting in the advanced page to turn off the adaptive switching but I don't know if that means it sticks with 20 or with 40MHz wide channels or if you can choose... I'll have to investigate tonight.
I'm starting to think this is the main issue.
lizabny:
Regarding your printer, I did have a printer issue before and it was due to the orbi allowing usage of channel 14 or something that the printer didn't support. I explicitly set the value on the orbi to not use that channel and it fixed it. You can perhaps search the forums for it.
FURRYe38:
I hope NetGear is paying you to be a 1st tier customer support because that's basically what you're doing here. It would be nice if they were more active. That being said, one thing a customer support person would do is encourage people to open their own threads to discuss instead of dropping the same debugging info which restarts a new conversation in the same thread. Just because someone says 'I'm having that issue too' doesn't mean it's acutally the same issue and it gets confusing reading 3 or 4 issues in one thread. It's also hard to point to it later as a solved thread.
Anyway, I mean that as advice and not a criticism. I appreciate that you're trying to help everyone here.
- poswaldNov 21, 2018Guide
OK just to confirm the help page within the admin console says:
Enable 20/40 MHz Coexistence
Disabling this option allows your 2.4GHz wireless to stay in supporting the max speed. Enabling this option may reduce the max speed of your 2.4GHz wireless to the half when there is another wireless network detected in your environment; this is to avoid inteference between wireless networks and to get along with other wireless networks in the environment.
I also confirmed it with a WiFi scanner. So that's not great. It seems like there's no way to set it to only use 20Mhz wide bands and stay that way. You're stuck with constantly switching or being a bad neighbor.
That being said, disabling this setting seems to have made things better in terms of Apple TV dropouts. I'll report back if it continues to happen.
Another data point:
I just had the Apple TV not stop streaming while it was connected to the 5GHz network and while playing from Apple Music even though the following was in the log:
[DHCP IP: 10.0.0.8] to MAC address c8:69:cd:39:89:bc, Wednesday, November 21, 2018 22:56:12
I'm hopeful this is working now but we'll see if it still acts right when it's connected on the 2.4GHz. Looking at the wireless backhaul networks the 2.4 and 5GHz are constantly trading off which one is up/down even when things seem to be working well but i'm not experienced enough with mesh setups to know if this is normal or not. I assume it is.
